Ortofon MC-3 Turbo
Zaczęty przez rudy-102, Luty 07, 2015, 23:30
Ortofon MC-3 Turbo
Frequency response                                                            20-30.000 Hz
Output voltage at 1000 Hz, 5cm/sec.                                     > 3.3 mV
Channel balance at 1 kHz                                                     < 1,5 dB
Channel separation at 1 kHz                                                  > 24 dB
Channel separation at 15 kHz                                                > 15 dB
Tracking ability at 315Hz at recommended tracking force            70 µm
Compliance, dynamic, lateral                                                  13 µm/mN
Stylus type        Nude Fine Line
Stylus tip radius        r/R 8/40 µm
Equivalent stylus tip mass                                                     0,75 mg
Tracking force range                                                            1,80-2,20 g (18-20 mN)
Tracking force, recommended                                                2,0 g (20 mN)
Tracking angle        20°
Internal resistance                                                              100 Ohm
Inductance        550 mH
Internal impedance, DC resistance                                          100 Ohm
Recommended load impedance                                               47 kOhm / < 500 pF
Cartridge weight        4,1 g
