Autor Wątek: Ortofon MC-1 Turbo  (Przeczytany 979 razy)
  • Wiadomości: 10113
Ortofon MC-1 Turbo
« dnia: Luty 07, 2015, 23:22 »
Ortofon MC-1 Turbo
Frequency response                                                            20-25.000 Hz
Output voltage at 1000 Hz, 5cm/sec.                                   > 3.3 mV
Channel balance at 1 kHz                                                    < 2 dB
Channel separation at 1 kHz                                                > 22 dB
Channel separation at 15 kHz                                              > 15 dB
Tracking ability at 315Hz at recommended tracking force            65 µm
Compliance, dynamic, lateral                                                  13 µm/mN
Stylus type        Elliptical
Stylus tip radius        r/R 8/18 µm
Equivalent stylus tip mass                                                     0,75 mg
Tracking force range                                                            1,80-2,20 g (18-20 mN)
Tracking force, recommended                                                2,0 g (20 mN)
Tracking angle        20°
Internal resistance                                                              100 Ohm
Inductance        550 mH
Internal impedance, DC resistance                                          100 Ohm
Recommended load impedance                                                47 kOhm / < 500 pF
Cartridge weight        4,1 g
« Ostatnia zmiana: Luty 08, 2015, 00:06 wysłana przez rudy-102 »
