Autor Wątek: Ortofon 2M Blue  (Przeczytany 972 razy)
  • Wiadomości: 10125
Ortofon 2M Blue
« dnia: Luty 09, 2015, 10:24 »
Ortofon 2M Blue
Dane techniczne:
• Output voltage at 1000 Hz, 5cm/sec.: 5,5 mV
 • Channel balance at 1 kHz: 1,5 dB
 • Channel separation at 1 kHz: 25 dB
 • Channel separation at 15 kHz: 15 dB
 • Frequency range at - 3dB: 20-25.000 Hz
 • Frequency response: 20-20.000 Hz + 2 / - 1 dB
 • Tracking ability at 315Hz at recommended tracking force: 80 µm
 • Compliance, dynamic, lateral: 20 µm/mN
 • Stylus type: Nude Elliptical
 • Stylus tip radius: r/R 8/18 µm
 • Tracking force range: 1,6-2,0g (16-20 mN)
 • Tracking force, recommended: 1,8 g (18 mN)
 • Tracking angle: 20º
 • Internal impedance, DC resistance: 1,3 kOhm
• Internal inductance: 700 mH
• Recommended load resistance: 47 kOhm
 • Cartridge colour, body/stylus: Black/Blue
 • Cartridge weight: 7,2 g
• Replacement stylus unit: 2M Blue (interchangeable with 2M Red)
« Ostatnia zmiana: Luty 09, 2015, 10:52 wysłana przez rudy-102 »
  • Wiadomości: 10125
Odp: Ortofon 2M Blue
« Odpowiedź #1 dnia: Luty 09, 2015, 10:30 »
Wersja Plag and Play
